Configure a hold-off timer to control when a signal fault is relayed.
| ring-name | Alphanumeric string that identifies the ERPS ring. |
| default | The default value, 0 milliseconds. |
| milliseconds | The interval for the hold-off time in milliseconds, with a range of 0 to 10000. |
The default is 0 milliseconds.
Use this command to configure a hold-off timer to control when a signal fault is relayed.
The following command sets the hold-off timer to 1000 milliseconds for an ERPS ring named “ring1”:
configure erps ring1 timer hold-off 1000
This command was first available in ExtremeXOS 15.1.
